What size carburettor is on there? AR is a 1300 case but 1600 barrels & ppistons can be fitted.
If your carb is a 30 or 31pict it is probably a 1300, if it has a 34pict then it is 1600.
There is no way to be 100% sure though without a the head off...
Pete is right. The case is universal (ish) The AR is a late 1300, single port 1300s are F prefix.
If you have a wierd looking inlet manifold with 2 heat risers going up each side, it probably is an AR 1300.
