1 - 8 of 8 Posts
The clutch with a ring went up to (<) 1972. If your motor is K reg it should be the later one. If your release bearing is held on by 2 flimsy looking U shaped clips and is not supported on a tube in the centre it'll be the earlier clutch with pad. If your release bearing slides on a tube and is held on by 2 clips already attached to the release, its the late one.
1 - 8 of 8 Posts
