Worn generator brushes on one side only… extremely fast
938 Views 5 Replies 3 Participants Last post by  Bada Ben
Hello!
I have been happily reassembling the engine and have been debugging the occasional red gen light popping on and off (at higher revs). Today, I noticed a lot of graphite dust around the generator, and opening the bottom plastic cover, was horrified to find that the bottom brush has been eaten away in a matter of days! The top brush is barely worn.
What could the culprit be? Spring tension? Wrong orientation at installation (see first pic)?
Hood Automotive tire Tire Bumper Automotive design
Body jewelry Finger Gesture Thumb Wrist
Tire Wheel Automotive tire Light Rim
Update: I replaced these new unbranded brushes with my old bosch ones, cleaned the commutator (fine grit sandpaper + contact cleaner) and all seems good now. No generator red light, no visible wearing of the brushes.
Getting a hold of decent carbon brushes is a mission these days as the new ones are cheaply made and not compressed under as high a pressure when manufactured. This then makes a soft material that will wear quickly.
I would, however, check for play in the genny's front bearing. This is cause the constant downwards pressure of the belt tension will cause the bearing to wear and pull down.
  • Like
Reactions: 1
I would agree, the combination of soft brushes and a worn bearing could cause the lower brush to get chewed very quickly.
If you find the bearing is worn, replacing it yourself is a worthwhile job, (especially if you buy the bearing from a general bearing supplier instead of any "Classic VW" parts specialist), but you will have to remove the generator from the car, to dismantle and get access to the bearing.
I recently replaced noisy rough bearings on my Beetle alternator with genuine SKF bearings from: simplybearings.co.uk , just over £13 for the pair.
  • Like
Reactions: 3
I had the gen out of the car in the very recent rebuild, and there is no play in the gen bearings. I did put the original lower brush in, and everything seems alright. I just guess the replacement brushes were indeed crap.
Clean smooth commutator + good hard brushes will last a long time compared to rough dirty commutator + soft replacement brushes.
  • Like
Reactions: 1
