1966 Beetle window handles
1 reading
651 views 10 replies 4 participants last post by  Bada Ben
#1 ·
Probably seems a daft question, but the drivers side window handle rotates anti clockwise to open the window. The passenger side handle rotates clockwise to open the window. Is this correct? I never really thought about it before but today the drivers side got stuck and I had to think about which way to turn the handle. Anyway should both handles turn the same way to open/close the windows?
Thank you
#2 ·
Unless a previous owner has installed different window winder mechanisms,
Left side regulator, turn the handle anti-clockwise to raise the glass:
Right side regulator, turn the handle clockwise to raise the glass.
#5 ·
I had to read this a few times to check... I think of it as the the way you move the winder when it is pointing forwards tells you which way the glass will go. Surely it would be weird if they didn't turn the same way on each side? (e.g. rolling forwards is down, rolling back is up)
I've never been in a car where they work any other way. 🤷‍♂️
#6 ·
Its not like rowing a boat, look at the mechanisms, the drive cog is on the top of the spiral cable, so the handles have to turn the opposite way for each side.
