21 - 39 of 39 Posts
Thing is, there's no point fitting a new clutch and refitting the engine if there is case compression and end float. Also some cases don't have a good oil return at the bottom of the case parting line and oil pools and sits at the bottom inner part of the seal. If/when you split the case an oil return mod can be done. New cases have this mod built into it
Discussion starter · #23 ·
Aye, I wont buy a clutch until I've at least checked the oil seal and o-ring. Splitting the case is not something that I can easily do in my current situation (or ever done). If there's nothing obviously wrong with the seals then I may just take a chance on refitting and hope my problems are related to the clutch release bearing - yes i know it's not ideal at all but it's a chance I will probably take.
Yeah, I'd agree with Garrick there. That amount of residue behind the flywheel is indicative of another problem - not related to your throwout bearing going out but likely related to your clutch slip. Combination of the two and maybe other niggles causing your issue.
Discussion starter · #26 ·
Finally got the flywheel off. What a mess:
That's an awful lot of oil, will replace the oil seal I took out and moved on to check the O ring on the flywheel and lo and behold there isn't one installed 😱 The indentation is there so with any luck I might get away with this one, though I'm not completely discounting a leak from my worn engine, but that's quite a part to be missing. Flywheel snout was fine no discernible wear. Will do those tests Garrick Clark suggested over the weekend.
Use petrol and a tooth brush to clean that goo off. I see white silicone too, so the issue has been there before you've owned this vehicle. The missing O ring is a biggie though. And a good find.
Try using a double lip seal
Discussion starter · #28 ·
I don’t see any oil seal or o ring with a double lip as an option looking at various sites.
What do you mean?
Discussion starter · #32 ·
It’s been a while, unfortunately work got in the way, but I finally got round to cleaning it all up and started to install the new double lipped oil seal. I haven’t put it all way in yet as I was quite surprised at how easy it was going in. It’s about flush with the edge now and I can’t push it in with my thumbs anymore (I do have the installation tool which I will use for those last few mm).My question is: is it normal for it to push in so easily even with the smear of oil on the outer surface? All the videos I’ve watched ppl either seem to have to use the tool or the old seal with a mallet to drive it in much earlier
The Silicone flywheel oil seals are easier to push-in than the stock rubber seals, because the little ribs on the outer edge are softer.
Instead of oil, you could use a smear of gasket sealant like Blue Hylomar or Curil K2 etc.
Did you also get a new O ring for inside the flywheel ?
I’d be measuring your existing clutch before ordering a new, make sure it’s not a 200mm clutch. Also if your replacing the flywheel oil seal I recommend you do NOT buy the seals available from the major Vw suppliers. I buy viton rubber seals these days from simply bearings. They are superior quality and don’t leak.
Discussion starter · #35 ·
ok, thanks, that’s somewhat reassuring. I’ll get some blue hylomar. Yes I have a new o ring also ready to go in.
Discussion starter · #36 ·
I’m not going to order a new clutch the one in there isn’t worn or that old, bought it for my old engine before the bottom end gave up. It only has about 2-3k miles on it. I did get a new clutch release bearing.
I bought one of those pink double lipped seals as suggested by someone else in this thread. Think it was from air cooled. If it’s really worth it I would be amenable to getting a viton one but I really don’t know the proper measurements.
I bought the cheaper seal, but they are both viton rubber which is what counts. These seals are what modern cars use, and can take the higher temperatures of an air cooled engine.
21 - 39 of 39 Posts
