elastic-trickery
825 views 8 replies 6 participants last post by  Sol Ford
#1 ·
howdo crew!
Anyone here good at electronics and basic circuitry?
I’m wanting to make a battery-powered dark-activated LED nightlight for my daughter.
I’ve been on some electronics forums but they’re talking gibberish at me :p
Is there anyone here who can help me in plain english? :)
#5 ·
Hi, thanks for the replies !
These are mostly solar-powered and no good for this project really
You can get such things off eBay for less than a fiver? Is it really worth making one?
I'm needing it to fit in quite a flat space and the ready made night lights will be a bit more trouble than it's worth to take to bits i think
If you really want to make one yourself you could try out arduino.
http://www.instructables.com/id/Arduino-Projects/
You can get the uno cheap on eBay, or maplin do the starter kits.
I've had a look for starter kits but none are really suitable so far...
What i'm after is a grid of 9 LEDs which are activated by the main room light going off... and then perhaps having a delay on them so they turn themselves off after about 15/20 mins... something like this-cheap-dark-detecting-led-circuit/ but a little more involved.
Trouble is, i know nothing about electronics - only bits that people have told me, like i should use a CMOS 555 chip to time the LEDs off... but i have no idea what one of those is. lol
#6 · (Edited)
#8 ·
I guess it depends on what you exactly want to build, but you could probably build something using totally off the shelf parts.
For example, car park lights all use photocells - normally 240v, so effectively you could splice one in as a switch on a standard type lamp. That allows you to use 240v standard type stuff.
Or:
http://www.ebay.co.uk/itm/Timeguard-TGLED-Plug-In-LED-Night-Light-Dusk-Till-Dawn-Auto-Photocell-TGLEDNL-/231151457428?pt=UK_Home_Garden_Night_Lights_Fairy_Lights&hash=item35d1b35494
Theres tons on ebay, all I typed in was 'dusk till dawn nightlight'. Some of them also have a Timed PIR so will come on with movement and stay on for a little while.
I have spent ages making various things and I found that actually it was easy to find something on ebay, its normally cheap enough and does the job.
#9 ·
We have a string of red love heart shaped lights as decoration in the little one's room. We turn the main light off when she goes to bed and unplug the love hearts when we go to bed.
You could even buy a plug socket timer and plug a lamp into it, if you didn't want to go into the room.
