one of the gaiters (the one with nuts and bolts to hold it together) is split on my bug, and oil appeared to drip out of it - could i be losing the gearbox oil from it? (i will be replacing it asap by the way!)
there seems to be a rubbing noise for each revelution of the wheel too - hard to pinpoint, but might be the rear bearing rather than the gearbox, as i assume gearbox noises would be a more steady whine?
never done much with a bug gearbox - is there a fill plug down the side of it, and does that also act as the oil level?
any advice please?
cheers
any advice please?
cheers
