Hi
I'm hoping someone can help me with this as it's driving me nuts. I'm tuning my VW T2 1978. It's hydraulic lifters so no need to adjust valves. So points ago is next. If I set the points gap using a feeler gauge to 0.016 and check it with a dwell meter the reading is 43. So way off the desirable 50 degrees. And if I set the points using the Dwell meter to 50 degrees the feeler gauge is nearer 0.013. How can this be right? The distributor is new (I should have left the points at factory setting). Any help to get me past this stag would be great.
